It is currently Tue Jul 22, 2025 12:26 am
PostPosted: Wed Mar 07, 2007 3:09 am
There was a request in the myrtle thread of a little update of what i'm working on at the moment, so here it is!
This guitar is the one that will hopefully get me my HND (higher national diploma) in musical instrument technology.
I went a little wild on this one - it's going to be a fanned fret 7 string, euro walnut B+S, euro spruce top, multi-lam neck and other such fripperies.
I'll post the pictures I've taken so far, with a small description of each.
First, the back and sides
Now the neck blank. I can tell you glue up was tricky, and messy! Because of the fanned frets, the nut is at an angle. When I come to thickness the headstock I will do so with a twist, moving the break angle and keeping everything neat
Sides bent (on a hot pipe, though I'm planning to build a side bender soon) Since the photo was taken I've put the blocks in and added the linings.
This is the rosette in it's current state - because of all the weird angles on the instrument I've had to do something strange here too - so spiral it was! The inlayed section is Brazilian rose, as will be the bindings and fretmarkers. The MDF is a mock-up fretboard end to cover what's not to be seen ;)
I've also nearly finished bracing the back. It's a self designed X. Hope it works!
PostPosted: Wed Mar 07, 2007 3:19 am
Andrew,
It's looking good so far. I like guitars that are different. I'd be interested to know how you cut the spiral for the rosette.
Keep posting the pics
PostPosted: Wed Mar 07, 2007 3:32 am
BRILLIANT to see another Brit on this yer forum!
I love the design elements of your guitar!!
PostPosted: Wed Mar 07, 2007 3:43 am
You mean you can get a degree for doing this stuff?!?!
Looking great...I too love to see different ideas tried out. Be sure to let us know how it sounds in the end.
PostPosted: Wed Mar 07, 2007 3:49 am
[QUOTE=Dave White] Andrew,
Keep posting the pics [/QUOTE]
Well the inside cut's done in the my normal way with a compass cutter on the laminate trimmer.
The outside was done using a template with a collar and cutter. I used the same template with different sized collar/cutter to cut the piece to fit in the route in the soundboard...
PostPosted: Wed Mar 07, 2007 5:28 am
Andrew, I really dig the look of the neck!! What is the materials in the
glue-up?
Looking forward to see how this one looks finished!
Long
PostPosted: Wed Mar 07, 2007 5:57 am
left to right...
Indian rosewood, maple veneer, ebony, flamed sycamore, ebony, maple veneer, indian rosewood
PostPosted: Wed Mar 07, 2007 6:59 am
Andrew,
I was the one who requested more pictures, and I'm glad I asked! Very creative, innovative work, and it even looks good, too! Start planning your diploma party now, my friend (and take pictures! ).
PostPosted: Wed Mar 07, 2007 7:36 am
Way to go Jammy, this should be a real looker. Keep up the good work.
PostPosted: Wed Mar 07, 2007 8:29 am
Love the rosette. I definately want to see pics when your done.
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Wed Mar 07, 2007 9:56 am
Last Name: Lloyd
Hi Jammy,
You bring some interesting concepts to the table. Well done and here's to your HND!
Michael Lloyd
PostPosted: Wed Mar 07, 2007 3:06 pm
Just stunning already. Keep it up!
PostPosted: Wed Mar 07, 2007 4:39 pm
First name: Larry
Last Name: Hawes
Nice job. I love different too. The rosette is really a great refreshing idea. Keep it up and be sure to let us see the finished product.
Thank You and Best To All
PostPosted: Thu Mar 08, 2007 2:15 am
Back's braced and everything's shaped up. Needs a little more clean up then it'll be ready to go on.
I'm pretty happy with the pattern, it feels like everything's well supported, and it looks pretty cool
PostPosted: Thu Mar 08, 2007 6:06 am
[QUOTE=jammy]...it looks pretty cool [/QUOTE]
It does, indeed! Whoever ends up with this guitar is going to smile everytime he looks through the soundhole. Nice work!
PostPosted: Thu Mar 08, 2007 6:28 am
That is far out!
I really like the way that is going,
If this guitar is for your HND (higher national diploma) in musical instrument technology
then mabye you can take some of the comments from some of the more accomplished luthiers and designers here at the OLF {and elsewhere} as the construction process progresses, and incorporate them in to your project what beter feedback can you get from some of the members here!?
Charliewood
